Go for multiflow condencer and evoporator for max cooling.. ..
The FF AC of Mehran contains multiple flow condenser with Denso Compressor. That really improves the cooling.
guys you can get lots of help from my page on similar research and details regarding AC installation in Mehran.
link is mentioned below
But dear brother people suggest that not to install used setup in a zero meter car.
Since you have new car stay away from used compressors.
i.e. means do not need to go for new oneif you want to install new then buy VXR mehran
but used Toyota compressors worked wonderful, its light, excellent coolling, work fine while stopping and trouble free,
No doubt kabli compressors work great but If you do not get a good piece, mechanics will ruin your new car by re-installing and replacing.
Agreed.Also if the kabli/used compressor goes bad just after installation then again you have to get the whole AC system flushed and condenser changed if it's a multiflow one because multiflow condensers cannot be flushed.
Hundred percent agree
Not agree with your recommendation to sale mehran and buy WagonR due to budget constraints.
BAND new is Denso and used one is duet compressor (actually its nick name of Toyota/Dahitsu Compressor of 660 cc cars),
No Brother its mehran 2012 efi euro 2 Old mistu cooling was not good its good for any 1000 cc cars especially old oneMost important1. Find mechanic which is best in your town2. take the mechanic while buying the compressor3- Ask for grantee to be replaced (usually people give 1 to 7 days as they had checked it by themselves) 4- do not go for repaired one as the compressors are not repairable these days.
Agreed First of all you have a honest consultant with you (mechanic/ac repairman)2ndly befor buying check the reputation of parts dealer, i have wasted 4 hours to find good compressor for my car. buts its worth it as its been 12 months and its working fine
If i do remember correctly then the Denso SCA06E is OEM compressor for Duet. And this compressor is also available NEW in market as well used is also available. But finding a good used piece is a problem and the price of new is around 12-14k i think so OP must take a wise decision on this.
Brothers what is difference between a Rotary compressor and Piston Compressor?What is multiple flow condenser?
I made A/C functional recently on 94 Mehran with Denso compressor and serpentine condenser (factory fitted multi-flow condenser removed) after full service. very light on engine, very good cooling, no heating issue at all.
ols mehrans dashboard has 4 ac windows and new ones have only two. Has anyone done any alterations in new model dashboard to make good 4 way cooling?
Bro which one u installed... I have purchased mehran VX 2017 wt u suggest which ac Denso is better it cost 25 K
Dear broWhat u did.. suggest me I have aslo purchased new car mehran vx 2017. And now wanna install AC .. which one is better if Denso or Denso is old .. and wt sandan is best for this era
