@jake13942 Thanks for the detailed thread. But a lot of people have missing issue in the this vehicle. Would you mind if we try to diagnose the issue? Your help will be really appreciated.
Service centers are absolutely useless. I have this intermittent missing since 5k ODO to 25k. I have changed the CAM sensors, changed the plugs multiples times. Been to all Glory dealerships.
Missing happens when you start to accelerate after cruising. As soon as you press the accelerator the car starts jerking and missing. You leave the accelerator and press it again it goes away. But as you keep the the pedal pressed it will keep missing.
Now I am trying to diagnose it myself. I think it's an issue with very lean AFR. On OBD logs I am seeing AFR as lean as 20:1 even where throttle is applied. I tried to match log times to the times it did missing during the drive.
