@imtishal,
Brother you are the only one out there who got the point across ...........so bravo bravo bravo to you!
You can get the genuine Honda coolant from authorised Honda 3S dealership, not available in the open market!
@brownhorse78,
I have tried to explain why would you need a genuine Honda coolant in your car in the previous post!
Here it should be mentioned that I am a fan of ZIC products and they also make good coolants as well, however after search I found out that it may Not be a good choice for honda therefore I decided to go for genuine honda.
Another example would be that if someone is not sure type of coolant recommended for the car, use the Caltex Long Life (orange color) it will be heavy on your pocket but it is the best and the latest technology.
Other than that you have the Korean coolants like GS, LLC and ZIC out there.
Have NO experience with the toyota or suzuki. Have no information about the type of radiators, seals and water pumps they make so I can not advise you on that.
But I can say it is a best practice to use Honda Genuine Type 2 coolant (which ever color that may be) for your honda engines.
Hope this helps!
