bro awesome work.....good luck with that....can you prepare it for cultus 2008....???
nice work brother , can you tell me which micro controller are you using , i recently did a diy using the atmel 8052 and made a keyboard 4 digit pin security system for my car , now will try to change the keyboard with 4 variable resistors so it will be 4 digit pin via some thing like this :
http://static6.depositphotos.com/1005979/663/i/450/dep_6637496-Dial-Knob-Turned-to-Max---Number-Level-11.jpg
Dude awesome work.You are giving me inspiration to build one for my volkwagen. Would you help me.????????????????????????????????????????????????????????????????????????I am a computer engineer so not much is to be dumped in me just the circuitry will be the problem as i never worked on PIC
how many cylinders (spark plugs) in cultus 2008?
PIC16F877A and PIC16F76Compiler MikroC for PIC
You burn the code your self , i have to sneak up in my x uni lab to do so... and what does ur system cost if i want to buy , maybe we can make the system more presentable
she got four cylinder and four plugs.
its four cylinder car bro
Thanks;This means same RPM meter can also be installed in Cultus?. As Alto also got 4 cylinder!
Superb!
thanks
Planning to replaced with graphics display (128x64 blue color)to make more presentable and nice look........................... PIC at start.................
This multimeter can be installed in khyber also...............
The major costly components are micro controller and displays... character LCD costs Rs.550. And graphics LCD that I am planning to installed cost RS 1250. Controller RS.350.
I can help you, If you want to make/install............
Yes........... If u interested..
Greatwork!Can you tell me from where you are getting RPM Analog Signal?
I have tapped RPM signal from ignition coil primary side..
Excellent Job Brother, appreciate your talent.,Is there any possibility to make a full setup for my daewoo racer. I will be more than happy to visit you with all necessary parts.Jazakallah
Superb mind blowing awsome talent
