@green bhai bahut bahut shukriya app ka
@mahmood bhai actually as i told earlier that only the problem i faced is that i didnot put the needles in correctly position, because i have to finish the job and i just wanted to know whether the leds are enough for this meter or not, and regarding glowing issue of the needles, actually the space between the spring and needle is very very less in km/hr,temp and fuel gauge, thats why i need to put a small 5mm white led just below the needle with 470ohms resisitor which helps to glow it, so i will buy these and check the market tomorrow. Regarding the 5mm led which iam talking picture is below:
@smijaz bhaijaan inshallah i will be doing much diys in future specially the deadning of sound which i heard after 140km/hr the road noise
@muhammadali bhai thanks
@xenerking yes iam using night breakers in my headlamps, i bought it from dubai for DHS280.00 almost 8 months ago when i was in ARAB HEALTH EXPO Dubai, and iam also going to Dubai in November spending vacation with my brother, so in Dubai u can get good brands like PIAA Intense White, Philips xtreme white, Osram night breakers and Original Phillips HID, Siemens and HELLA cost around starting from Dhs 250-650.00 I just bought phillips HIDS in Januray with Osram night breakers for my uncle Camry which comes with projection light, and believe it works really good and better than chinese one.
@yahujee bhai thanks for appreciation, actually i will not change the leds, leds will be remain same, i just wrap a tinting paper, or i can paste on the backside of the cover of meter as i have totalled sanded it.
