How to give speed input to the ECU of the EPS?And any idea if somebody has already done this in past?
wire splice it in from the VSS wire going to the ECU
You have to change the steering rack (kanghi) as well. The EPS installation will not be as simple as alto or cultus.
There is no ECU in 2004 2.0D Saloon.
How does this EPS mechanism looks like?
Is the motor mounted on the steering column? or on the R&P itself?
Thank you.
The cluster gives out a VSS signal - use that.
