assyed00bhai jao internt khula hay to searck karlo
api level/grade ka oil change interval sey koi door door tak wasta nahee hay
ur dirt opinion is also wrong
similarly engine hay yaar ,koi khula teen ka dabba nahee key desert mey jaeey gaa to engine mey dirt jaey gaa
engine completely sealed hota hay, cvcaccum hota hay, air tak to jate nahee hay,agar small hole bhee ho jaee tootherwise pressure will create, too much noise will come,pickup will dead
bhi oill filter 10,000 km ya 5,000 per kuch nahee hota change ke liye
,filter hamesha quarter oil rakhta hay apne andar, ap new oil dalo ga then it willl mix with ol dirty oil of filter & thus make all new oil to be dirty in 2-3 minutes
so u r qrong
oil filter always to be replaced with oil change
i think ur education doesnot related to your job in anyway,if u r not MBA urself then dont underestimate MBA's & thier techniques .
How much u have experience u cannot be compared with even fresh MBA ,whether u worked in saudi arab or dubai or uk, fact remians fact
oil performance has no connection with API level,it is standard of
just writing "International Institute" doesnot make weight in your point,please search on internet 1st,then think,after that write
please check on google or any other search engine,be liberal yaar
on wikipedia:
API standards of oil :
The American Petroleum Institute gravity, or API gravity, is a measure of how heavy or light a petroleum liquid is compared to water. If its API gravity is greater than 10, it is lighter and floats on water; if less than 10, it is heavier and sinks. API gravity is thus a measure of the relative density of a petroleum liquid and the density of water, but it is used to compare the relative densities of petroleum liquids. For example, if one petroleum liquid floats on another and is therefore less dense, it has a greater API gravity. Although mathematically API gravity has no units (see the formula below), it is nevertheless referred to as being in âdegreesâ. API gravity is graduated in degrees on a hydrometer instrument and was designed so that most values would fall between 10 and 70 API gravity degrees
History of development
The U.S. National Bureau of Standards in 1916 established the Baumé scale (see degrees Baumé) as the standard for measuring specific gravity of liquids less dense than water. Investigation by the U.S. National Academy of Sciences found major errors in salinity and temperature controls that had caused serious variations in published values. Hydrometers in the U.S. had been manufactured and distributed widely with a modulus of 141.5 instead of the Baumé scale modulus of 140. The scale was so firmly established that by 1921 the remedy implemented by the American Petroleum Institute was to create the API Gravity scale recognizing the scale that was actually being used.
To derive the API gravity from the density, the density is first measured using either the hydrometer, detailed in ASTM D1298 or with the oscillating U-tube method detailed in ASTM D4052. Density adjustments at different temperatures, corrections for soda-lime glass expansion and contraction and meniscus corrections for opaque oils are detailed in the Petroleum Measurement Tables, details of usage specified in ASTM D1250. The specific gravity is then calculated from the formula below and the API gravity calculated from the first formula above.
Generally speaking 40 to 45 API gravity degree oils have a greatest commercial price and values outside this range have lower commercial price. Above 45 degrees API gravity the molecular chains become shorter and less valuable to a refinery.
Crude oil is classified as light, medium or heavy, according to its measured API gravity.
Light crude oil is defined as having an API gravity higher than 31.1 °API
Medium oil is defined as having an API gravity between 22.3 °API and 31.1 °API
Heavy oil is defined as having an API gravity below 22.3 °API.
Not all parties use the same grading.[1] The United States Geological Society uses slightly different definitions.[2] Simply put, bitumen sinks in fresh water, while oil floats.
Crude oil with API gravity less than 10 °API is referred to as extra heavy oil or bitumen. Bitumen derived from the oil sands deposits in the Alberta, Canada area has an API gravity of around 8 °API. It is 'upgraded' to an API gravity of 31 °API to 33 °API and the upgraded oil is known as synthetic crude
