well sensor was not faulty,it was the wiring that was causing the issue,which was fixed and i had a safe trip and didnt had to change the sensor
now i have to get it checked as to why its pick is not upto the mark
btw when i got its plugs n air filter changed 2 days back,its idling dropped till 500rpm,so does that effects anything?
Reset the ecu after you change air filter or clean throttle body.
checked it today when car was not warmed n after drive of 10minutes,idle rpm is below 500rpmi think it effects braking atleast
how to reset ecu?
remove ecu terminals if it is easily accessible or simply remove battery terminals for 5 minutes
idling had dropped below 5k rpm n even with AC its still the same,so car never warms up n i have to press brake so hard n still it dont stops at once :S
it is on petrol or cng?
its on cng
