@ kdiesel
Q: Why you had to change the gear, Is is possible to use 2E tranny with 4AFE??
A: I changed the gear because of the compatibility with the engine. so that it work good in terms of pick and speed.
Yes 2E tranny will work with the new engine and the fitting is the same..
Q. And what initial problems did you face? what about EFI wiring harness?
A. No problems ... EFI wiring and all (complete process) done by Electrician with that Vendor..
@awais52
Yes the guy installed the genuine harness.. they have with them.
No he didnt install the check engine light.
Yes my car has tachometer. And I didnt install advancer / emulator, no use of these gadgets, CNG works good with out those.
