@tashfeenchem, just by looking at engine or listening to its sound, talking to the user; ONLY STUPID "G" class criminal mechanic will suggest the engine swap.
plenty of symptoms as in high fuel consumption, smoke at throttle, oily exhaust, morning smoke, blue smoke is sign of bad valve / worn rings. Possible bad tappets, leaky valve seals, etc etc.
visit a workshop which can perform compression test. Wet & dry readings shall not be under 160 psi. lower values are not good sign and engine need overhaul.
Suzuki engine overhaul parts are available brand new and engine overhauling is not rocket science. With help of engine service manual you can supervise the overhaul job. why ? because you can read write & understand English better then your mechanic, plus you have edge of having guidance from PakWheels.
engine will be as good as new for next 300,000 Plus kms with correct oil grade and regular maintenance.
state your city and mention engine oil grade you've been using. share maintenance history if available, please.
