You got the right ECU with your engine.
and now, as you mentioned above, RPM is different and throttle positioning is different. There is a tab under some menu on the scanner to calibrate the throttle, but i do not think this Autoboss scanner can do this. Find a good scanner, like Autel or G-scan I told you. or go to Nissan Gandhara Rawalpindi, they have Consult II, i used it once.
