NDS2 shud work with your Nissan, hobDrive is seems like made just for fuel issues, where is Fault Code option in hobDrive?
NDS2 may need some settings in your case, check out its configuration. By default it works on ELM v1.5 wifi device, switch it to Bluetooth device and vice versa.
Yesterday I forgot to put the radiator cap back after checking the water level, on the way engine temp raised. Thanks to Allah, that I placed the Electronic Throttle Engine, agar wire driven hota to gaskit bachni nai thi.
Electronic Throttle ki waja se ECU ne Accel freeze kar dya and as I plug the ELM v1.5 and launched the NDS2 here was the output.
Error Code P1217 on Top.
Sent from my Z12 using Tapatalk
