m18's mostly here are with auto ecu's how did you get a manual ecu and gear from?are you sure it's m18's not m15's?
can you elaborate it?how did you do it?
lol comparison with 1zrfe auto,with poor 4speed badly synchronized tranny?try beating a 6speed altis mine do it way before than this,ive beaten auto r18a aswell.
Rafay ;
wats your car 0-100 ?
^^^^havnt checked yet but we have done some big tweaks,we ate 1.8 altis,se saloon,stage1 d15,stage1 swift.
if you can give tuff time to a 21 lacs car with a simple 7 lacs car its more than enuf
@shamron post engine bay pics!
yar post some pictures of engine bay and installation procedure
pics of ecu
2006 SUZUKI Swift Sport - Sport car technical specifications and performance chk swift sports does in under 8.3 seconds ..... but some websites claims as it does in 7.8 second ..... so m18 should be quick but keeping in mind your car is bulky than swift so it will be higher values but not that much high as you getting .... chk your AFR might be you running too lean ....
Is your VVT ON ?
What is your fuel cut RPM value ? if it is same as 6700-6800 than the gear you are using isnt of m18 as m18 has short ratio gears so it shouldnt go till 115 ... it should be like 95-100 in 2nd gear ....
hmmmmmm ..... !!
ahan (H)
lol i wasnt talking about swift,i was tALKing about my altis
lol...edit.refered to the second pic as both ecu's are different,and if its liana's stock,bother mentioning it
@rafay you know na....15's and 18's tranny suck literally.poor ratios and bad synchronization.
@poster post 0-100 run video.btw lower your car,liana got serious traction loss problem.
nah that isnt with m18,the blue one is stage1 only,the one which won piston cup.the one SpoonMotorSports is refring is white.
Sir jii ap to gayyab he hugaye hain .... no lift
Didnt win ... he was 2nd !!
