Now its time for the Interconnect
Using a low quality and Chinese interconnect or even a base model interconnect was not my purpose. I needed an interconnect which was meant to for audiophile reference grade clean signal transfer.
For that i begin my search but no interconnects were available in pakistan which would suit my build. So atlast i found one interconnect and had to go heavy on my pocket to buy it. This will be the main RCA which will be delivering the signal from HU to DSP in trunk. (Dsp will be revealed later)
As this RCA had to go all the way to the back from front so it had to have all the noise rejection capabilites so that clean signal should reach the dsp for further processing.
This cable is being presented for the First time in pakistan.
Presenting : Audison Connection ST2 550 Interconnect
ST SERIES HIGH RESOLUTION AUDIOPHILE SIGNAL CABLES
DURA-TEXTM outer jacket for protection and to enhance the feel and flexibility
SOFT TOUCHTM outer jacket makes for an extremely flexible cable
110% TWISTED MYLAR AND DOUBLE ALUMINIUM shield rejects RFI and EMI
DDWTM (Double Drain Wire) system to drain electrostatic fields. No noise
WTPTM (Winding Twisted Pair) balanced conductors reject low frequency electro-magnetic fields aiding in noise rejection
OVER 115 dB noise rejection
PLATINUM SATIN machined ABSTM style connector for a strong, long lasting connection
TUG-PROOF sealed internal connection for maximum reliability
DIE-CAST Y BLOCK for full protection of the conductors in critical split point
REFERENCE GRADE performance
More RCA's on their way
