UP for grab is the fastest allmotor of Pakistan, Honda Accord Euro R .
The basics are :
Islamabad number VIP
Electric Blue color
k24/k20 type R
Model 2003 imported 2007 in prinstine condition.
The car is dynoed at HPR and tuned on kpro
the HP is 350.
other details are:
cams,springs,retaners,valves,guides,cnc port polish,port and polished manifold,775 injectors,70mm throttle body,exedy 3puck clutch exedy light weight flywheel,12.9 pistons,rods,bearing, thrust washer,crank polished,oversizes sleeves,oil pump chain ,guide, baffle plate,10k rpm modified oil pump,wideband bosch,custom headers,exhaust,3,4,5,6 custom gears ,short gear final final drive, quaife lsd, aluminum oil pan,3 gauges, 4 potenza 17 semi tyrs,dc5 rims, tien shoks,act bearing,hks super fire racing plugs, stock modified rocker arms,hondata kpro,custom harness with dual ecu,
stage 3 cams, titanuim retainers, dual springs, retainers, head port polished, rbc port and polished manifold,fic 775cc high impedence injectors, commetic gasket,12.7 high compression pistons, eagle i beam rods, crank polished,10k modified dc5 oil pump, oil pump chain, baffle plate, guide, acl rod,crank and thrust washer,custom made short gears ,final drive custom teeth with wpc heat treated,straight cut all theeths of gears,aluminum oil pan,hondata kpro engine management, exedy stage 2 clutch , exedy ultra light flywheel, 70mm throttle body, tien coilovers, hks super fire racing plugs, dc5 rims with potenza semi slicks, 5zighen fireball 3 inch exhaust system, custom made headers, highly maintained on mobil 1, hamp oil filters, fujitaba long tube cold air intake, hks mushroom filter.
