Translated via Google Translate
NetEase reported on August 25th the Besturn second vehicle, B50 finally welcomed their first small face lift.
Although in appearance the previous year models has virtually no difference, but this on its own brand cars in Europe are of mixed blood still causes us concern.
B50 is the result of FAW besturn and Giugiaro led the Italian company IDG crystallization together again.
After the pre-high wedge-shaped body of low and low-drag streamlined design reflects the strong coupe design elements, drag coefficient of 0.28 beyond imagination, far beyond the 0.3 model on the same level or above level.
In the shape design can be seen at a glance the B50 and B70 blood relationship between each other.
But B50 appear to be more younger & more dynamic.
Crystal diamond on the challenges of the pentagon headlamps and grille are all great and B70 intake is said a pulse, but there is just a little soft.
B50's rear design is distinctive, officially called as the "duck tail."
Is said to reduce air drag coefficient by about 20%, so that high-speed fuel consumption reduced by about 14%.
And B50 double-waist design side and also show their feminine sense of beauty full of force the other side.
And 2011 models replace the previous year models not the color of the 9-spoke wheel design, but with a similar Mazda6 coupe 5 V-design wheels.
FAW Besturn in the configuration for B50 has done some hard work, and enough to make its class with admiration.
B50 high end models have cruise control, sun sensor with automatic temperature sensor inside the car air-conditioning systems.
The instrument panel of
011, B50 has additional 120Km / h speed alarm function, when the speed over 120Km / h, the buzzer will ring three times, to prompt rapid speed.
In security, the Besturn B50 hardness with softness in the nest safe design concept, the whole body frame is designed in accordance with European safety standards. The body is 360 ° all-round strengthening of 3H security structure, the core parts of a submarine shell with high strength steel, and more than 40% of the ultra-high strength and high-strength body material, ranging from thick steel plate using laser welding technology. Also equipped with dual airbags and front seat side airbags, and use the Bosch 8.1 ABS, for the vehicles to provide a solid security guarantee.
B50 from the blood is definitely in terms of a "Eurasian." B50 uese a "double-wishbone independent front suspension" and "E-type multi-link rear independent suspension" structure, not only has excellent handling stability, and closely heritage of the Mazda6 and the Besturn B70.
The engine is equipped with a classic FAW-Volkswagen 1.6L engine as in Jetta. This engine technology is mature, there are more than 2.3 million in domestic holdings of units, so the usage cost will be relatively less.
The Besturn B50 is equipped with five-speed manual gearbox, while the Aisin six-speed tiptronic transmission to shift more smoothly also has better fuel economy.
The B50 is equipped with Pentium 3G technology combines GPS navigation live configuration, DVD player, music player, streaming video player, TV, Web browser, image viewer, text browsers, vehicle status display multiple functions.
Multimedia display below the three slots, respectively, SD card, USB and the most important SIM card slot.
The first two are better than say, as long as you wave enough, with three companies "awarded" the 3G mobile phone cards can be inserted SIM card slot to offer 3G B50 enjoy life.
Besturn B50 has been adhering to bring you a good idea for the love its own brand models offering consumers with a richer choice.
