No need if the engine is performing as desired
https://www.facebook.com/groups/837295116454899/permalink/1735551479962587/?app=fblarticle by Automark magazine regarding situation and concerns of FAW V2 owners after its potential discontinuation
FAW V2 parts are available at Pakwheels auto store
https://www.pakwheels.com/accessories-spare-parts/search/-/?q=faw%20v2
Use Toyota gear oil GL-4 75w-90 oil,and the issue of gear shifting will be resolved, the required oil is 2 Liters.FAW v-2
Anyone had issue with steering? The motor is acting weird. Its pulling on one side and quite stiff and require force to rotate to opposite side. I got no EPS light on but issue is there. If I remove power to motor then there is no pulling on any side. I changed the steering rack so that is ruled out. Anyone had such issue or could provide a solution pls chip in.
Recalibrate it.
How?
Using Obd2 tool.
Problem solved. They placed steering column at a wrong angle
Nice. Recalibration would had centered it again. Although calibration is always needed after mechanical work.
No. It was physically disoriented. But thanks for your help.
Still having clutch plate issue. Car vibrates very badly in first gear...anyone is having same issue or any possible solution...??
Can you help me regarding Faw v2?fuel average, parts availibilty etc?
