i think 15 is for low speed marine diesels
This is what Wikipedia has about compression ratios
The compression ratio is a single number that can be used to predict the performance of any engine (such as an internal-combustion engine or a Stirling Engine). It is a ratio between the volume of a combustion chamber and cylinder, when the piston is at the bottom of its stroke and the volume when the piston is at the top of its stroke. The higher the compression ratio, the more mechanical energy an engine can squeeze from its air-fuel mixture. Literally, high ratios place increased oxygen and fuel molecules into a reduced space, thus allowing for increased power at the moment of ignition. Higher compression ratios, however, also make detonation more likely.
The ratio is calculated by the following formula:
, where
b=cylinder bore (diameter)
s=piston stroke length
Vc=volume of the combustion chamber (including head gasket). This is the minimum volume of the space into which the fuel and air is compressed, prior to ignition. Because of the complex shape of this space, it usually is measured directly rather than calculated.
Due to pinging (detonation), the CR in a gasoline/petrol powered engine will usually not be much higher than 10:1, although some production automotive engines built for high-performance from 1955-1972 had compression ratios as high as 12.5:1, which could run safely on the high-octane leaded gasoline then available. Recently, with the addition of variable valve timing and knock sensors to delay ignition timing, one worldwide manufacturer is building 10.8 CR gasoline engines that use (U.S.) 87 octane fuel.
In engines running exclusively on LPG or CNG, the CR may be higher, due to the higher octane rating of these fuels.
IC racing engines burning methanol and ethanol often exceed a CR of 15:1.
In engines with a 'ping' or 'knock' sensor and an electronic control unit, the CR can be as high as 13:1 (2005 BMW K1200S)
In a turbocharged or supercharged engine, the CR is customarily built at 8.5:1 or lower.
In an auto-ignition diesel engine, the CR will customarily exceed 14:1--and over 22:1 is not uncommon.
Contents [hide]
1 Fault finding and diagnosis
2 Saab Variable Compression engine
3 Variable Compression Ratio (VCR) Engines
4 Dynamic Compression Ratio
5 External links
[edit] Fault finding and diagnosis
Measuring the compression pressure of an engine, with a pressure gauge connected to the spark plug opening, gives an indication of the engine's state and quality.
If the nominal compression ratio of an engine is given, e.g. as 10:1, the measured pressure in each cylinder of common automotive designs can be roughly estimated in pounds per square inch as between 15 and 20 times the compression ratio, or in this case between 150 psi and 200 psi, depending on cam timing. Purpose-built racing engines, stationary engines etc. will return figures outside this range.
If there is a significant (] 10%) difference between cylinders, that may be an indication that valves or cylinder head gaskets are leaking, piston rings are worn or that the block is cracked.
If a problem is suspected then a more comprehensive test using a leak-down tester can locate the leak.
[edit] Saab Variable Compression engine
Because cylinder bore diameter, piston stroke length and combustion chamber volume are almost always constant, the compression ratio for a given engine is almost always constant, until engine wear takes its toll.
One exception is the experimental Saab Variable Compression engine (SVC). This engine, designed by Saab Automobile, uses a technique that dynamically alters the volume of the combustion chamber (Vc), which, via the above equation, changes the compression ratio (CR).
To alter Vc, the SVC 'lowers' the cylinder head closer to the crankshaft. It does this by replacing the typical one-part engine block with a two-part block, with the crankshaft in the lower block and the cylinders in the upper portion. The two blocks are hinged together at one side (imagine a book, lying flat on a table, with the front cover held an inch or so above the title page). By pivoting the upper block around the hinge point, the Vc (imagine the air between the front cover of the book and the title page) can be modified. In practice, the SVC adjusts the upper block through a small range of motion, using a hydraulic actuator.
The SVC project was shelved by General Motors, when it took over Saab Automobile, due to cost.
[edit] Variable Compression Ratio (VCR) Engines
The SAAB SVC is a very late addition to the world of VCR engines, the first being built and tested by Harry Ricardo in the 1920s. This work led to him devising the octane rating system that is still in use today. The company has recently been involved in working with the 'Office of Advanced Automotive Technologies', to produce a modern petrol VCR engine that showed an efficiency comparable with that of a Diesel. Many companies have been carrying out their own research in to VCR Engines, including Nissan, Volvo, PSA/Peugeot-Citroën and Renault.
The Atkinson cycle engine was one of the first attempts at variable compression. Since the compression ratio is the ratio between dynamic and static volumes of the combustion chamber the Atkinson cycle's method of increasing the length of the powerstroke compared to the intake stroke ultimately altered the compression ratio at different stages of the cycle.
[edit] Dynamic Compression Ratio
The calculated compression ratio, as given above, presumes that the cylinder is sealed at the bottom of the stroke (BDC or bottom dead center), and that the volume compressed is the actual volume.
This is not true: intake valve closure (sealing the cylinder) always takes place after BDC, which causes some of the intake charge to be compressed backwards out of the cylinder by the rising piston at very low speeds; only the percentage of the stroke after intake valve closure is compressed. This "corrected" compression ratio is commonly called the "dynamic compression ratio".
This ratio is higher with more conservative (i.e., earlier, soon after BDC) intake cam timing, and lower with more radical (i.e., later, long after BDC) intake cam timing, but always lower than the static or "nominal" compression ratio. The actual position of the piston can be determined by trigonometry, using the stroke length and the connecting rod length (measured between centers). The absolute cylinder pressure is the result of an exponent of the dynamic compression ratio. This exponent is a polytropic value for the ratio of variable heats for air and similar gases at the temperatures present. This compensates for the temperature rise caused by compression, as well as heat lost to the cylinder. Under ideal (adiabatic) conditions, the exponent would be 1.4, but a lower value, generally between 1.2 and 1.3 is used, since the amount of heat lost will vary among engines based on design, size and materials used, but provides useful results for purposes of comparison. For example, if the static compression ratio is 10:1, and the dynamic compression ratio is 7.5:1, a useful value for cylinder pressure would be (7.5)^1.3 × atmospheric pressure, or 13.727 × 14.7 psi at sea level, or 201.8 psi. The pressure shown on a gauge would be the absolute pressure less atmospheric pressure, or 187.1 psi. From this, we can see that the two corrections for dynamic compression ratio affect cylinder pressure in opposite directions, but not in equal strength. An engine with high static compression ratio and late intake valve closure will have a DCR similar to an engine with lower compression but earlier intake valve closure.
