Removing thermostat valve is not as easy, as like in corollas its easy to remove thermostat valve, for honda its little difficult to remove and installing it back as its self is a one hour job and whereas in Liana its located in worst of the places which will easily consume two hours. That?s why I had to perform the flush while thermostat was intact and later flush the system again 4-5 times with water in-order to get rid of flushing chemicals.
thats the price you have to pay sometimes, in some engines the thermostat valve is a POS design. and in some cases the valve is built into the flange, meaning you need to find a complete bad valve and gut it out.
Learned this the hard way. But this type of work is DIY here. Not many mechanics are willing to do such stuff.
does any one knows the air bleeding screw in alto????
there is no bleeding screw in alto, you have to raise the car on ramps or park on a slope or front wheels on foothpath and rear on the road, make the system burp itself slowly as it warms up. install cap and leave it - dont open it everyday.
thanks Xulfiqar bhai............
When you have plan for rad flushing, tell me, I will have some suggestions for Alto regarding air bleeding ....
Tell me ... Tell me i am planing to do this in coming weekend
plz do share,,,and what is this air bleeding?......can u elaborate!!!
Air bleeding is to remove air from cooling system.
how u do air bleeding?
As u asked, here is pictures to get access to clutch adjustment screw and T- joint
thankyou.......
one thing more brother..........T joint has three pipes.one from engine,second to heater,what is the function of 3rd pipe, u say that third is connected with cng kit.RADIATOR PIPE WITH CNG KIT..............CONFUSED:confused:
The 3rd one circulates coolant (from engine) to CNG kit to maintain CNG kit temperature within range.
okay...
Mere pas 2006 model ki alto hai magar radiator main jab bhe pani daltay hain tu aik dam se radiator nahi bharta thora thora pani daltay rehna parta hai
AoA Talha.
I also need to flush my radiator and need your help, can I call you or email t discuss please ?
AoA .
I also need to flush my radiator and need your help, can I call you or email t discuss please ?My number is 0333 2132329
May i know if tstat valve required rubber seal around it in alto vxr or not?
