CDI system main 6 coil generator hota hai which supports 12 volts.
Point system main 2 coils hoti hain 6 volts ki, ek starting coil kehlati hai aur starting current provide krti hai,
Doosri coil headlight coil kehlati hai aur woh headlight/backlight/speedometer lamp ko jalane aur battery ki charging ke liye use hoti hai.
Point system main electronics aur starting coil dono 6 volts ki hoti hain,
Jab aap point system pe electric ka nizaam 6 se 12 volt krwate ho to electritian aapki headlight/charging coil ko 12 volt pe rewind kr deta hai.
Is se current 6 volt ki jaga 12 volt hojata hai aur 12 volt ki accessories chal sakti hain point model pe.
Starting coil 6 volt pe he rehti hai.
Loag electronics krwa lete hain 12 volt pe par results koi khaas nahi hote balke light aksar 6 volt se bhi ziada bad tar hojati hai.
