if you have a separate gauge then when you press the fuel button the fuel from auxiliary tanks is used...simple it doesn't shift it.
yes sir it has a separate guage for subtank above the rear view mirror along wid alt meter !
thnk uuu every1 for ur guidance , meant alot willl try it nw n update u
bro with in a secd es ko kam kerna chaheya ... ager to it means kharab hai
oy
Eid Mubarak to all friends
khair mubarik aamir bhai!
eid mubarak to all friends
khair mubarik Aamir Bhai ...
thank u amir bhai and frontier 4x4 club EID MUBARAK from arrk30...
khair mubarik mamaki!
Warroke Akhter Ombaraki staso tolo ta..........keep your 4x4's off the road and keep on tracking...
Tested it , it switches fuel source on pushing subtank button thnx guy for ur help
Tell me abt its routine maintainance plz ? If accidently i left the hubs locked n disengaged 4wd n drove it wht r da concequences ?
staso umbarak sha:D
Happens most of the time with me but if your rig is maintained well (front diff oil checked and changed on time+hubs maintenance) then nothing to worry about.You probably didn't do anything but get bad mileage. If it is still engaging and disengaging & there is no grinding or howling you are good to go.
Alryt thnx , after hw much mileage to change diff oil ? Gear oil ? Which engine oil will u recommend , whn to change ? In a petrol engine v regularly clean the throttle body n plugs , wht abt diesel as it doesnt have plugs ?
diff & transmission i usually change after 25k kms.engine oil i will recommend Delo gold,zic 5000,mobil..change depends on where you drive dust etc but i would go with the 3k mark.you will find glow plugs instead of s.plugs so check them once a year.
[video=vimeo;72887041]https://vimeo.com/72887041[/video]
[video=vimeo;72887889]https://vimeo.com/72887889[/video]
Thank u brother ur guidance is appreciated will ask u if had more querries
I have sent the route maps to aaRK30!All drivers are requested to pick up their route maps from Khizer Hayat (AARK30)at his place on Monday.
9007 in action after a long time.
