@babarhailian
Only adjust Tappets when engine is very cool, Almost not working for 4 -6 hours. If we adjust tappets when engine is warm is a big problem.
Check tappet plate, if it has some cuts replace it with good one, Normally exhaust push rod start to cut tappet plate after few hundred hours of running. This is main problem on 5K + Chinese generators.
In night time check spark plug wire , it is not leaking current to generator's metal parts, The one which came with generator normally start to tease. You can get spark plug black wire (which is connected to ignition coil) from car auto store, Use a thick sleeve. Hardly a 50 Rs fix.
You can dismantle Ignition coil and observer its metallic transformer like core, If it has rust on it, clean it with Kerosene oil or WD40. If still no success, Change the Ignition coil with a bigger one which can fit in your generator.
I have gone through similar problems a year ago. Now My generator obey first self every time since a year. It tease after every 3 months for tappet plate change only.
I hope that will help, but in either case tell me,
Thanks
OmRON
