1- Detach your kit from generator (no need to remove pipes)
This is what your kit should look like
2- You have to unscrew this button from its base
Unscrewing (It should come out by bare hand)
Button removed
Looks like this
Pressing the button makes it look like this
3- Stick a needle at the base of button and press both button and needle at once (you have to insert the needle with the button so that the button won't come out and make sure it is permanently pressed)
4- Wrap squash tape on the threads on the base of button so that when you reinstall it, it may not move with vibrations even if it is fixed with just a couple of turns in it's hole.
5- Cut the excess tape hanging beneath the threads by scissors.
Should look like this
Put it back in hole and just give it a couple of turns to tighten it (DO NOT FULLY TIGHTEN IT; NOT MORE THAN TWO TURNS)
Fix the kit back
The button will now look like this from side
Remove the pipe going to carburetor and lit a fire at opening. there should be a small flame, you can increase the flame by turning the button clockwise and reduce it by turning it anti. keep about half an inch of flame and fix the pipe back. Now start your generator, but make sure to adjust the Spark plug gap and adjust tappet before it. If your gen start on first crank, then pray for me; if it doesn't then try increasing the flame a little bit more, your generator shouldn't demand a flame of more than 2 to 3 inches.
Best of Luck; Now you'll be ready to make an ATS; believe it that ATS thing is worth your time, money and effort.
