It Helps In Improving The Braking System To Work More Efficiently Over Stock Rotors
The advantage of slots is that it dramatically improves stopping power,
Helps To Remove Dust & Water Away From Brake Pads Keeping The Rotor Surface Cleaner To Allow More Grip By Pads
One More Important Advantage Of Slots Is The Way It cools The Brake Pads & Rotors Surface
Eliminating Brake Fade Or Loss Braking Ability.
The Drilled Holes Is To Allow Heat That Bulit Up B/W The Rotors & Brake Pads Surafce To Dissipate While Ride Has Been
Driven Long Period Of Time & This Disspation Of Heat Helps The Prevent Rotors Warping & Extend Life Of Brake Rotors.
As Due To Drilled Holes It Allow Air To Pass So That Rotors Are Less Heated Which Again Helps In Good Grip & Result Good Braking.
It Also Looks Attractive & Aggressive On Ride By There Pattern.
& Many Other Small Good Factors Make These Kind Of Rotors To Perform Very Well Over Stock.
