I would recommend you to use Liquioly Ceratec in addition to normal service incl. oil and filters change and get the timing belt checked as well.
I have used LM Ceratec in my HJ60, 3980cc, 6 cylinder, diesel engine, the engine has done 257000 miles (its london model) about 410000 kms without overhauling, so I thought there would be alot of wear inside the engine, and the jeep was having rough idling, after putting two LM Ceratec 300 ml bottles (one bottle is enough for 5 ltr engine oil in my case engine oil is 9 ltrs so I put two) now my jeep has very smooth idling, pick has also increased and its giving quite good mileage around 7-8 km/l in city and 10 km/l on motorway at aspeed of 100-110 km/h, these figures have been tried and tested several times.
Also use LM diesl purge, it will remove blockage from the nozzles resulting in good mileage and smooth drive.
