Took the car to Osama. After investigation we found out Car's engine assembly is changed. It has k24a installed. CM5 came with k24a4. The same engine number is mentioned on the car's body. The gear and ecu both are of k24a4. Do you think that's the reason behind the pick and 2nd gear jerk? We are still looking into the wiring and valve body (to figure out the solenoids condition)
