Turab Ali Malik Brother above comment of KhanBhai is positive sign
now you must get your bikes headlight & visor fitting checked as
KhanBhai told his dream's visor is not making any noise even after harsh tests
so this could be case, you have gotten CG Dream piece whose visor & headlight is not fitted rightly
may be nuts & bolts are not tighten and it is very common thing in pakistani motorcycles
oh KhanBhai come on kindly please share the news
Automotorsport brother no its no normal i mean as normally the needle should be stable
should not shake yes agree this problem many people might have faced but one should only
worry if problem does not get resolved with meter cable adjustment or replacement
i give you example of my friend CG which he had driven around 10k suddenly his meter
needle started shaking during one of trip with me he became worried but his problem
was resolved just with tightening of cable it was loose from meter joint
so mechanic just tight the cable and meter was running fine
