Now comes the most important part: Removal of the control cables. Take a LOT of care while removing them, don't bend them, else consider yourself in considerable amount of trouble.
After you've removed them, insert your spanner, the same one you used to open the screws, inside the dash like shown in the following picture and push this clip from inside.
Take care and do it calmly and carefully, its a bit tight in there. Will take u a few minutes to figure out how to do it. Once you do, push it and the central console will pop out with a click.
This is how the popped out console will look:
Now, gripping it from the lower side, from the knobs preferably, pull the console out.
Do it carefully: Don't apply unnecessary force, just give it a slight jerk and it should come out. Applying continuous force may result in damage since the cables inside aren't THAT long, they might break or become loose.
