Asalam o Alikum
I encountered a strange problem while travelling on GT Road yesterday on my City 2006. The car was driving fine but suddenly it lost some pick. I could not cross 80 kms per hour even in 5th gear even with my race paddle pressed hard, sometimes the car would regain its pick and start driving normally until i keep the race paddle pressed and then pick drops again if i release the paddle or change gear. Also on going to idle the Rpm suddenly drops to 400,500 and then goes back upto around 900.
I got the car inspected by a mechanic. He opened the plugs and found that ONE of the plugs was wet. He said that water had come into the plug which might have been caused by overheating. He told me to get the head of the engine opened and check/replace the gasket. I did not see any Engine hot sign in the dash board and the coolant level was where it is supposed to be.
Any advice in this regard will be really appreciated. Thank you
Solution: One of the fuel injectors was apparently not getting any current therefore one cylinder was not working. One electrician identified the fault. two plugs changed for 400 Rs (due to being short) and 400 for services. Problem solved in 800/- Rs. Alhamdulliah
