Bro 3000-8000 per pair depending on location and type, e.g Chinese made are cheaper, Taiwan made are a little expensive. Also prices vary from model to model, i bought 3000 ka pair 2007 model City. (Gujranwala)
Bro i am using Total Quartz Grade 20W/50 engine oil in my Honda City 2007 IDSI Vario, i am satisfied with the performance and i replace the oil every 4000km because its an old car, i also have to change the transmission fluid which ive been told to use a CVT Fluid made by the Honda Company as per Vario is a CVT transmission from my research here in Pakwheels and other forums. Your cars engine health is to be taken into consideration for engine oil plus frequently changing oil companies may deteriorate engine performance according to the senior pakwheelers so you should probably ask the previous owner which company he used.
Can anyone share the user manual of city 1.3 ivtec?
front camber was within tolerance. Toe needed a bit of adjustment. Dont know whats up with the rear camber though, not adjustable.
hi ..i want to buy honda city within the range of 10lac..i want to know that whether 2004,2005,2006 models is good or not?and what is the monhlty expenses on this?need ur advise..thnx
2004, 2005 and 2006 are excellent cars if you can find one in a good condition. Very good fuel economy (14,15 km/l) and you get to drive a sedan. Maintenance is cheap and monthly cost depends on the car's history. If the previous owners took care of the car you won't have to spend much on maintenance.
My car has clocked 80k and mileage has dropped significantly it used to give 16-17kmpl as my usual route is clean carpet roads, but lately it has reduced to 12-13kpl
new honda city 1.5 prosmetic or civic oriel 2016 (10th generation) which one would be better..pls suggest
Not a good idea, price is too steep! Highly recommend Altis (2017-2018) slightly used in that range.
1.6 altis? i heard corolla is not good control on high speeds like 100+? further, grip and turning radius is also not as good? and why not civic then?
i am not fan of either but i prefer better control and easy drive over soft suspension so its always trade off
When you change the oil for the first time, they didn't put whole 3.7L of the oil because you didn't change the oil filter and approximately 0.2L oil is always in the oil filter. Therefore honda always puts 3.5L when you do not change the oil filter. So there's some oil always in assembly and filter, hence we always see a difference of +-0.5L.But I'm still wondering how did you calculate the figure 0.5There's no way to do so via dipstick.
195 45 17Do you guys think this is a suitable size for city?Form and Factor both.
Absolutely not. Do not go above 185 65 15 for maximum driving pleasure in a 2009 and above model.
The height of 195 45 17 is almost stock size
this is way off. 195 60 17 is almsot stock height.
https://tiresize.com/calculator/
Those engineers who designed honda and the aerodynamics are really very sensible people. They have chosen 185/65/15 very wisely. Please don't play with it, for your own safety.Rest its your private property, you can do anything you want.
Guys any idea about the own money in Isb/pindi on city 1.5 prosmatec.
