How did you fix it there? With glue?
Some glue at edges, mostly with rivets.
Price is reasonable. If it will differ from the picture you can return it to seller. On daraz this works well. If product is different from advertisement they gives the full refund.
what is this material, where did you buy it from and for how much?
It's a piece of thick carpet, intelligently cut into shape to be held by rivets.
Scenes kch aesy hn k Government ny FED khtm kia e krna tha ab PickUp trucks means double cabins ko b FED me shamil kr dia ay
Since vigo will be expensive... grande will feel economical...kia logic hai this legendary emaandaar government ki
Why do these useless Honda people insist on changing the drain plug washer at every oil change? And why do they charge 120 rs for a piece that costs like 1 rs in open market? These washers last a very long time.
Cuz it is a crush washer and it is not supposed to be used again. The proper and correct way is to use a new one whenever the drain bolt is opened. The one used by dealerships is a OEM Honda part with a proper part number that's why it is expensive.
This washer is made from especial alloy metal. It absorbs the extra torque applied to drain bolt. Aftermarket washers are made of leather. They do not absorb all the torque and there are chances of chamber damage on every oil change. In such case after few oil changes chamber needs new threads. Chamber needs to be removed for this purpose and its a very expensive repair. After market washers are prune to damage and if oil leaks during a long journey there are fair chances of engine damage. Even with the OEM washer, keep an eye on any oil spills for a couple of day after every oil change. It is a life and death matter for the engine
Our city 2014 is not starting. My father took it on a trip and came back home. After a few minutes, he started the car but it did not start. What could be the reason?
Ac, fan , headlights, infotainment system; everything is working but car doesn't start.
May be fuel pump has problem.
1- Low oil pressure. Check the level of engine oil and add a little if lower than MIN mark.2- Immobilizer battery. If you have immobilizer in your car but I think 2014 do not have it.3- Low battery power. Check the voltage of the battery during cranking. If they drop below 11 volt battery is dead.
It doesn't have any immobiliser or aftermarket security system. The car doesn't crank.
Check the battery voltage. Check the main fuse attached with battery terminal. Check the starter fuse.
Battery down agr crank e ni ho ri
Can someone please guide me for these points
Does aspire (2016 to be precise) have front camera wiring already?
And if we install front camera can we record it with original tracking world navigation. If yes then how
I have this exact issue in our 2010 city. I had discussed it with a mechanic and he said that it can occur due to failing of some carbon bushes. But I think I should have the evaporator cleaned first.
No. I have late 2018 model and it only has reverse camera wiring.
