The drain bolt crush washer is the same as the one used on the oil drain plug, 14mm size. They will have that.
The fill bolt crush washer they usually never have in stock. You have to ask them to order it in, 20mm size. part no. 94109-20000.
But i have to change oil immediately is there will be any issue if i dont change these bolts ?
Its about changing the washer, not the bolt. If the crush washer is ok you could reuse it. At least change the drain bolt washer, 3s will have.
What about price?
the 14mm washer, is rs110. the 20mm washer is rs40.
Thanks bro but today i have changed the oil and oil wala said that there is no need of changing bolts so i have only changed the oil
How much honda charges for Manual Gear oil replacement including oil price?
