i want to share some oem parts number of sx8 if it could help someone
OEM honda part number for shocks absorber:
honda part number:51605-sx8-t01
Kyb part number: front right 338708 front left: 338709
brake disk honda:
45251-SB2-940
PAD SET, FR:
45022-SX8-T01
Air filter:
17220-P2F-Y00
wiper blade
38472-SB2-003
some info regarding honda city sx8
tappet adjustment at cold
intake: 0.18-0.22mm
exhaust: 0.23-0.27
Recommended oem spark plugs:
NGK BKR6E-1
manual transmission oil:
honda mtf or caltex delo gold(delo gold is recommended by Xulfiqar and also cheaper )
never use gear oil or atf oil in manual transmission it will ruin your gears
Ignition Timing:
stock ignition timing is 12 degree. it is carried out with shorting two pin connector at dashboard and use timing gun light at idle speed (750 rpm) and use timing gun to adjust distributor at crankshaft pulley you can see the details in video
https://www.youtube.com/watch?v=MKmr6PfhCR0
more tips will be uploaded about the car
