Here it is
Sent from my HUAWEI G510-0200 using PW Forums mobile app
Another angle
Here are the pistons
Damn!
Sent from my HTC One X using Tapatalk 2
Heart surgery in progress. Let's see what ustad surgeon recommends, a bypass or a heart transplant Good luck
Have taken pics in my digital camera will upload them in the evening.the pistons seemed to be okay ustad told me that only the assembly will cost around 45 k and the over haul rough estimate under 40 well did dis assemble all the engine tomorrow i will come to know the exact cost when he gives me the list of parts
Now back home left the car at the work shop. Well this rebuild is a gamble lets see what turns out.
Piston in the oil pan
ripping the engine apart began like this
The head being reomved
after ispecting the cylinders the mechanic said that a simple gasket change will not do the job the block needes work to be done and needs to be taken out or the other option is get it swapped he gave me both options i gambles with the overhaul.30- 40 k might go down the drain but iam mentally prepared for that.
Good Going Bro. But from engine condition, it is obvious that swap will be better option than overhaul. In many cases, overhaul get failed and money as well as time will waste.
So go towards swap,it will save money as well as your time.
I agree with @galant1 DONT overhaul it, if you overhaul this it wont be reliable!! This assembly has completed its life, its of no use no matter what you do, and in the future it will cause you more problems..
lets see what does the mechanic say having a complete detail look at the engine. never checked the gasket and the distrubutot o ring thats from where all the oil came from
Here is the bill of parts purchased..are the rates ok
Today i went to buy the parts costed me around 22 k
the gear assembly after getting geting rid of the horrific oil and grim layer
Plans for tomorrow.. will install a new radiator and silencer old one might be clogged means another 10k addition to the overhaul expence :). A kabli dual nali has to be found yet was getting some china one single nali for 5500.
