AOA guys!
Yesterday bought a 2004 VTI Oriel Manual with original D16W9 engine.
I am facing two problems,
The RPM is on the higher side, in 5th gear at the speed of 80 the RPM is around 2500 and @ 140 the RPM is above 4000.
While driving some times when I press the accelerator, the ECU gives a ticking sound and the car gives a jerk (like the acceleration stops for a second) and the everything is back to normal.
Today after driving for 30-40km, the check engine light came on, the car didn't turn off, but the power steering stopped working and RPM went to Zero. I turned the car off and then back on and everything was back to normal. This has happened twice so far.
But when the check engine light was on, I tried connecting the OBD2 dongle, but it couldn't connect with the ECU. Whereas, in normal condition, it was connecting properly with ECU.
Anyone else faced such problem and what could be the issue?
