i just went to a local mechanic, He scanned for abs error and i got a rare left wheel abs sensor error.
and again i checked the abs by pressing hardly on a new road, again i have found only right tyre skidding.
So, The mechanic first told me why their is no ABS Light on the ODO Meter? well as far as i know their isn't any light for ABS on Reborn if we turn on the ignition. correct me if i am wrong.
As per the mechanic logic the ABS is failing because their is an error at the left rare tyre, He said you have to change the rare break pads, the front ones are OKAY .and we will see further what other issue are their and we will also service the break disks because their are lines on it. 5k minimum He asked for this.
i am actually not sure whether he will fix it or not.
Q1). Does reborn rare wheels also stops at breaking? until now i thought only front wheel are responsible for stoping the car.
Q2) If their is an issue on the left rare tyre then the left rare tyre should skid. how it is that only right front tyre is skidding? or as the mechanic tell that it was because abs failed when it receives any error from any tyre.
Q3) Does reborn have ABS light indicator when we switch ignition?
