Then your car may not be driven 114568 KMs. My father's 2007 Honda Civic Hybrid is maintained from Honda Center Peshawar Road since it's import. It's driven 177k kms now and it reduces the same amount of oil it did when new; only 30-50 ml which is normal. Some oil is always stuck inside the oil filter and pipes, so don't count that.
Check any pipes that might be leaking. Put a cardboard sheet under the car overnight and check for any oil stains. Have a compression test done; it's the only way to tell if the engine is okay or not. The cat-con is usually removed when people face a power loss.
