Thanks, I will try to contact
Looks like there is some current flowing problem in the wiring as the car starts ok if you turn on lights for a while. This was discussed once by @Xulfiqar but I forgot how he elaborated it.
Yes I read all @Xulfiqar reply in @hasankhurshid29 post but no luck.@hasankhurshid29 I see you face 100% same problem in same car.Kindly help.Thanks
@hamxahamid
Check the starter ignition switch and also check for starter issues as well
I don't face this issue. I own 6th gen civic not his genI posted on behalf of another member who created that thread
@hamxahamid it was his thread
Please help him if your problem resolved
oki Thank you
Contact me on whatsapp. 0348 4204482
@hamxahamid sure.Thanks
Sir problem resolved or not? Im also facing same issue, help me if possible.
Yes Finally after 3 month this issue was resolve.Changed: TDC sensor, tappet adjustment and timing
I spend 35 K Rs for this problem but issue was not resolve and at the end gone Islamabad Honda AMX and they done a great job,
Thank you very much @raziurrehman7 for sharing your experience.
Recently I also got the same issue and the mechanics were unable to diagnose the problem so then i changed my TDC sensor and my problem has resolved.
It cost me only 3500 for Kabli original sensor the price for china made is 1500 which is not recommended to use.
Same problem faced by me in my Honda 2020.In extreme cold weather the car wont start early in the morning, After some time when sun rises and car left in sunshine for some time then it starts in one self. .I wonder what to do and which sensor to replace?
@hassan1991 @Spano @rajaatta
It doesn't start at all or it takes time in early morning only?What is the condition of battery? I will not doubt any sensor until i'm sure about voltages supplied and fuel.
thats mostly because of weaker battery.in that case, you can pour gyser water (warm/hot water) on the battery and it will start even in the cold.
I have faced similar situations in case of weak battery and cark parked for over night in the open
@capsat
an old blanket shall be cut to size and wrapped (stitched) with cable ties around the battery at start of cold weather. That will help in summer preventing battery heat up and does not freeze in winters @Xulfiqar
very trueall construction vehicles up north have insulated battery compartments some are customized by oem some are "jugar" by the MT shops.
Aoa allI am not sure if anyone is going to read this but Am facing the same issue.Can you share the picture of that TDC sensor.Thanks
