@mtauseefsa if you get your dvd navigation system code please tell me the pass code i have also the same problem can you solve my problem its been a pleasure for me.you can send me on my mobile no. 03360897955 or my email add Ramishiqbal417@gmail.comthanks for your cooperation
can you give me the code
Hello to this helping community im having following set of errors on my machine, it appears and disappears automatically can you please tell me what can be the possible root cause of this problem and whats the remedy of it its 2014 model n X package, thnx in advance
Dear Colleagues,
can anyone suggest good long term service stations for Honda Vezel 2014 in Islamabad/ Rawalpindi?I am living in Bahria Town and office is in F-7 Markaz.
Thanks in advance.
Can i change language (from Japanese to English) of Navigation System of my Vezel 2014 Z Package?
If not, is there any good brand available in the market to replace with original?
Kind regards,
Asallamoalikum Please add my # to Vezel WhatsApp group.I recently purchased 2016 RS zero meter03215016606
AoA
No you cannot change the language, neither you can run Pakistan maps so if you want to use Navigation you will need to replace the head unit, PM me your contact and I can arrange for you.
Do let the Group know your recommendation on the head unit.
Salam ... i am also facing the same problem ... slight clunking noise when car accelerates slowly .... more pronounced when engine kicks in at low RPMs ... did u find any cure or reason for it ? ... mine is 2013 X imported in 2017... this sound disappears at high spds ... and no sound with car at stop and engine running ..
This is certainly not the kind of sound one would pass over.In my opinion requires to be looked into.If you have read the past posts on Vezel you may have read that there have been some issues with regard to 2013/14 models.I sincerely hope that its nothing and will not cause you any serious problem down the road.Is it a continious noise or just when the car shifts from engine to hybrid power and vice versa.
Can someone tell me why my recently imported Honda vezel hybrid is giving just 8.5km per litre fuel average?
Fuel consumption is highly dependent on driving style, use of air-conditioning, Air Filter condition and most importantly tire air pressure. Clean air fiter, fill tires with company recommended air pressure and drive normally and hopefully it will improve.
Visit this
Plus you need to get it scanned from some place. Preferably from toyota dealerships or someone who has an advanced two way scanner. Only a step by step procedure can diagnose the real problem
Bro can you add me on vezzel group my number is 0332-2283332. please add asap
What is the fuel average of honda vezel? I am going to import one, but listened that vezel consumption is not going; gives not more than 15-17 km/l Please share your experience
Depends on how you drive. Normally it does between 15 - 23 kmpl.I've been constantly getting 19- 22. And i've driven it 40k kms.
Absolutely right.This is the average one gets depending style of driving and driving conditions.
AOA I own a Honda Vezel and at times I am driving the computer says something in Japanese at times it's a long sentence and at times there are just few words. Can you or anybody help me what does that mean?
How much those seats cover ??
Need Help. My car Honda Vezel 2015 got issue with Even Clutch Pressure Engagement Performance due to Clutch oil circuit. This is verified by checking clutch oil which was drained due to driving the car on intense rainy flooded road.
Now the only option is to change the clutch assembly. I have no clue to where i can get this part and from which workshop it should be done in Lahore.
Honda service point here in Lahore has no clue or expertise about it. Any suggestion is highly appreciated.
Regards
