Well you should of course be changing the engine oil with 0w-20 synthetic at every 7000 km. Then you need to be changing the actuator fluid every 10000 km or less if you want to be safer, for that you can use any decent dot 4 brake fluid, some local mechanics call it "clutch oil". At around 130k kms on the car, you'll also want to get the engine carbon cleaned by spraying cleaner into the throttle body of the car while revving it at 3000 rpms, as Vezel is Direct Injection, carbon builds up inside the engine so it's very important that you get that done too. at 160,000 km you want to change the atf using genuine honda atf dw1 ultra which many people in Pakistan get confused and start changing that every 10,000km. you only need to do that at 160k and every 60k after that! As for where you can get this done, there is a service center on main pwd road by tehzeeb bakers with ZIC sign on the top, theyve been servicing my 2015 Z and my friend's 2014 X for 2 years, Mine has 166k kms still driving amazing. If you have any more questions please do let me know
