Starlet chemical quite reliable
Sent from my SM-N910C using Tapatalk
Sangjani or jhelum gravel could be the best with cement from kallar kahar belt
Cost of ehxavetor digger anyone?
Sent from my iPhone 6s using PW Forums
Depending on area and depth.I paid 15000 for 1050 of total area and extra 4 feet all around for 10ft depth.
You can also give him the mud in exchange for the digging service.
What's the going rate for labour only construction these days?
same question. I need it for lahore
any one knows where to find the white AAC blocks for outer walls. these are very good insulated materials made and very light.quite common here in Kuwait but in pakistan ?also iam planning to use plain surface grey blocks.. the one commonly available are not very plain and can not be fixed vertical. hence costing more money and wastage.plain block can be fixed more verticaly giving more coverage,less plaster cost and fast masonry...
No one...?
Depends upon area currently working on two small projects in Lahore. paying Rs. 225/- sqr feet in Shadbagh area and Rs. 255/- in Johar Town area.
Ayaz
Only Grey structure is from 225 to 260. If you include electricity & plumbing then add Rs. 30-35
This was mean for you.
Just got contact with a chinese firm through alibaba.com for hebel white arreated blocks.Still not got the price quotes but fingers crossed for a affordable innovative building idea...
Can anyone clarify difference between tesi krandi and grey structure?
Tesi kandi refers to all the work which will be done by tesi & kandi i.e brickwork, plaster etc.
