Time for another marathon. Tamam hazrat say guzarish hay kay hazmay ki goli kha kay yeh post parhein.
First of all Ahmed bhai you need to post the sound clip of that tick tick sound so that we can comment exactly what is it. For that tick tick sound there are 2 things.
1 Knocking
2 Engine
Lets take the first case i.e knocking. First of all very important thing is what is knocking. Knocking is the ignition of air fuel mixture at a time when the piston is moving upwards i.e still in the compression stroke. As the piston is moving upwards and is connected to crankshaft so it cannot move downwards immediately with the ignition hence it hits the piston hard and produces a sound that sounds like knocking. To my limited knowledge 80-90% of the time knocking is related to ignition timing.
Another question arises here is that why the car from factory does not knock and when they are old they knock. The reasonse for knocking are
1 Petrol which has very low RON.
2 Antiknock sensor not working or some other sensors not working optimally
3 Timing too advanced for the operation of vehicle under use.
First of all coming to petrol and RON. Higher the RON of petrol the slower it burns i.e the time it takes from a spark to a big flame. This means that the fuel that has low RON will burn quicker than the one with high RON. So the petrol we have in Pakistan is of low RON and will burn quickly and produce knocking. To eplain this we have to consider something about ignition timing, what is it. Ignition timing is the timing when the air fuel mixture is ignited. It is measure in degrees BTDC i.e before top dead centre. As the mixture is ignited it formes into a big flame certain degrees ATDC i.e after to dead centre. Now comes the point that higher the RON of fuel the greater we have advance its timing so that the ignition turns into a large flame certain degrees ATDC. Every engine has its specific ATDC for optimum performance. Now take a rough example. Suppose an engine is made for 91 RON fuel and its timing is 10 BTDC such that flame is produced 5 ATDC now the burning time of mixture is 15 degrees i.e 10-(-5). Now suppose we feed the car with 93 RON whos burning time is 17 degrees. Now if we dont change the timing what will happen that the flame will be produced at 7 ATDC far beyond engines most effective performance point. To take care of this what we can do is advance the timing so that flame occurs at the most optimum point. Advancing the timing by 2 degrees is the right action but if we advance the timing but 7 degrees now what will happen. With even 93 RON fuel the flame will occur at 0 ATDC too away from most effective point and with 91 RON it will occur at 2 BTDC and will produce knocking. That is the reason our cars that are run on CNG knock on petrol and keep in mind that RON of CNG is well beyond 100 RON so optimum performance is not possible for both fuel.
In efi cars we use advancer for the advance of timing on CNG and it advances according to its calibration. Another thing in most efi cars and the one under condition particularly is that the timing changes with rpms and demands of engine. Why an engine requires to changed its timing with the changing rpms. The answer is that as the rpms increase the timing between each movement of a piston in the cylinder decrease so if the timing is not advanced it wont be possible for the flame to be produced at optimum ATDC, because we cannot increase the burning rate of fuel with our changing demands. So the ecu works like this it tends to retard the timing at lower rpms and advances it at higher rpms.
As the signals to the ecu are fed by sensors so the sensors have to be working correctly for proper operation by ecu. The sensors that come to my mind are knock sensor, TPS, MAF sensor, O2 sensor they all have to be spot on even one of them is not performing the required performance cannot be achieved.
If we take this tick tick as anything other than the knocking than it can only be said after hearing the sound. And yes talha bhai said its coils. Coils can also be the culprit because because they might be sending the current to the spark plugs too late and that is why knocking
Now coming to the conlusion and remedial actions to take.
I dont think its the carbon buit up thats causing the problem because each time the piston moves up the oil cleans the cylinder walls so there is less of chance of carbon built up there. The knocking is usually not permanent I mean to say its not on all engine speeds. i,e a engine can not knock at all engine speeds ideally most engines dont knock at higher rpms because there as less time to burn is require so the fuel that was causing knocking in low rpms would not knock at higher ones. Now the remedial actions are I would like to advise is that find yourself an idsi that is on low miles and runs perfectly. Connect to OBD II scanner to that car and note down the readings like, timing, and there are other things as well that I dont remember. Take all readings at 500 rpm interval i.e at 1000,1500,2000 so on till 5500 rpm. Because the owner of that second car is not going to allow you redline his car:P infront of his eyes. Now take a drive and again note down the readings at different speeds i. 30,50,60,70 etc. But here you have to keep the rpms and gear noted because you are going to take similar test on your car as well so you can be in a better position to decide. After all the readings have been noted take the same readings on your car. Now compare both I hope that you will find the culprit. As your car is a high miles car and its run on fuel >100 RON so it seems a pssibility that some or any one of your sensors has malfunctioned or about to die so it is not sending proper signals to ecu to retard the timing and hence producing knocking. Check engine light only lights up when a sensor if fully dead so if its working on its 10% the CEL wont light up.
Still I will be waiting for the sound clip to know what actually the sound is. Do update us about the results
Regards
