As you have already dismantled the AC system it is advised that you also remove the evaporator unit and clean it as well.
Buy new O-Rings and the recommended oil as per the requirement of the compressor.
When filling refrigerant from the can never invert it, if the can temp goes too much low put it inside a bowl filled with hot water, you can also use a hot air gun but be gentle with that.
If you can afford, buy a 30lbs cylinder and fill it by weight that way you will never go wrong, but you will need a weighing scale for that.
