@naughtynaveed11
Location of ECT Sensor is near the ignition coils and thermostat valve, where radiator's upper pipe connects with engine. See the picture below
Also note that most of the time electricians have messed up with the wires of ECT sensor, therefore wire colors may not be those I mentioned (i.e black on pin-1 and green on pin-4)
Let me tell you an easy way.
Step-1) Locate the large (about 1 sq. inch size), black grip of ECT sensor
Step-2) It has a lock or notch or a button type thing on upper side, press it gently and pull the grip
Step-3) Hold the grip in your hand in such a way that its holes or connection points are facing you and its lock notch is on the upper side
(see pic of C21 connector above)
Step-4) Now the upper-right point is Pin-1 and lower-left point is Pin-4 (see pic of C21 connector above)
Step-5) Now on the back side of connector identify the wires which are going to Pin-1 and Pin-4
Step-6) Uncover these two wires gently and give them a twist with each other or use a small wire to connect them. Apply some tape on the joint.
Step-7) Reconnect the grip firmly
Step-8) Start the engine and do not switch on AC, note that Check Engine Light must not be ON
Step-9) Radiator fan must start when temp needle reaches near the dots
Step-10) If fan does not start, switch off the engine and check every thing carefully. Go to some electrician if the problem is not solved.
