that sounds goood!!
oil pump
Engineering (khradya) works
Head after khradya works
You should have asked for advice before commissioning the engine work. Don't mean to burst your bubble but one should not trust mechanics. You should have gotten a compression test on all the cylinders to really know if it needed a complete overhaul or not. If compression would have turned out to be fine, you only required a head job and nothing else.
Its just my brotherly advice no offense intented...Bro had u done the compression test ?? I can bet that there wasn't any need for complete overhaul. Head job would have made ur motor alive again.
PS: Try to use 110% genuine parts from minor to major..
:-#:-# 60,000 for complete overhaul ?? Man even 3s dont charge that much..
bro I did compression test and it was the final nail in the coffin that made me to go for a overhaul.. before the car was showing signs like white smoke, bad rpm and in the last day 2 out of 4 spark plugs stopped passing current due to fault in the cylinders
I didn't noticed that before.. im also. going for a complete overhaul but with a cost of about 32k
One thing more, after the overhaul, remove this intake and get the stock one back. This will not increase any power, infact it is adverse for the engine
the parts bill says 0.25 undersized main and big end shells but the pistons and rings are STD? Did you resleeve the block or were the bores good but pistons broken?
It contains all new parts including Radiator and the thero switch, each and every thing because of my IDIOT and STUPID Driver so called an army retired person
army folks treat vehicles like orderleys - They expect it to run without complain forever. To me "army officer owned" means completely worn out scrap metal on wheels.
btw - was the block resleeved?
