The hid light was flickering so I took it to suzuki. After complete check up of wiring, ballast, bulb, relay the culprit was the relay which he changed. But during the process the headlight had to be dismantled to take out the bulb.
It was resting on the front fender when unfortunately the handle moved and the light fell. It didn't touch the ground because it's parking (neon ring) wire was connected to the clip which had held it.
Due to the shock 'jhatka' I think the wire is detached. The neon is not working. So if you guys know about any expert who can fix that problem please let me know about the contact.
As you can see in the pics the wire coming from left side is detached a little bit.
Sent from my Galaxy Nexus using Tapatalk
