That's a lot of stuff you have. Was the aim to go loud (spl)? Different products, different characteristics, different sounds isn't really a great way to set up a setup.
Regardless, I'd suggest you up your wiring. Is it 0/4 or 8 gauge? Do a big3 and add some inline fuses. Are you power/gnd wires ofc or cca? Even if you upgrade your alternator or add another battery, a mehrans wiring can only take so much beating. For a setup of this caliber, you would need atleast true 4 gauge ofc wiring. Do the big3 with 1/0 gauge and if it's in your budget, run 1/0 gauge or 4 gauge to your amps. Make sure the pwr and gnd wires are the same size.
Get the wiring upgrade done, then figure out your next upgrade
