It's a 1.5 ton
I know why the amps are high, I don't worry about the amps, it's the power that matters.
Let me explain:
If an appliance need 2000 watts of power to perform its duty, it is going to consume 2000 watts, no matter if the volts are 180, 200 or 230. If volts are low, it just sucks more current but the power consumed remain the same. You only measure amps to multiply with the volts to calculate the power. Just measuring amps is a useless exercise.
example of my ac
220volts x 8.1amps = 1782 watts
160volts x 10.8amps = 1782 watts
Energy meters outside the houses measure your power consumed not the amperes.
Inverter AC's don't need any stabilizer. It's better to spend on appliances that can work on low volts instead of spending on stabilizers, most of them in our market are poorly designed and waste energy.
