Salam
Pls suggest me which one I should choose
1 or 1.5 ton, Brand also
Room is 180 sqft and 11 feet height, Max temperature even in June is 34 C, shaded, no direct sunlight from any side, bit well insulated, no kitchen or extra heat source attached, 2-3 persons normally, will be used around 15-16 hours/day, ground floor also
Considering room dimensions, it's obvious 1.5 ton, but considering heat load, technician suggested me that 1 ton will be quite enough, I personally think same
Like heat load will be around 9000-10000 btu
I'm confused
I came to know that 1 ton ac stabilizes at higher amperes and others also suggest that even in small room you should go for 1.5 ton as it stabilizes at lower amperes.. Maybe it's a myth but I'm not sure
I was personally interested in Mitsubishi inverter but not sure regarding their after sales services, so now Gree in mind now, should I go for gree? Isn't it overrated?
Pls suggest any other model (2019, 5 star) and share your reviews regarding that,, so that I can decide
Regards
